configure upm event
configure upm event upm-event profile profile-name ports port_list
Description
Configures a pre-defined event that triggers the named profile.
Syntax Description
upm-event Specifies a pre-defined event type: device-detect, device-undetected, user-authenticate, user-unauthenticated.
profile-name Specifies the profile to be configured.
port-list Attaches the UPM profile to the specified port(s).
Default
N/A.
Usage Guidelines
This command configures a profile to be executed when the specified event occurs on the specified port(s).
You can configure multiple user profiles on the same port(s).
The following example shows how to configure a profile on port 1:1, called “profile 1” that is triggered by the event “device-detect”:
# configure upm event device-detect profile "p1" ports 1:1
This command was first available in ExtremeXOS 11.6.
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the Universal Port feature, see the Switch Engine v33.1.1 Licensing Guide document.
